Bremsen E Abs
dominik
PLZ: 79
Tätigkeit: Elektromeister
Re: Bremsen E Abs
Beitrag von dominik »
Solution 2 will be a good way.
I have done this with two cars, while changing from 288mm solid rotors to 308mm floating rotors.
Miguello80
Roller: E-Odin 2.0 6kW AMR
Land: anderes Land
Re: Bremsen E Abs
Beitrag von Miguello80 »
dominik hat geschrieben:
Fr 8. Dez 2023, 09:08
What do you think about this ? :) Chinese, but floating = should not suffer to warping like classic discs. Yyeah, buttons can get stuck over time but it is easy to clean them. But still 300 mm (grinder will solve it) + possibly need to buy new bolts..
https://www.chinesemotorcyclepartsonlin ... rt/BRDF031
dominik
PLZ: 79
Re: Bremsen E Abs
Not all chineese things are bad.
Just try it.
Zurück zu „Dayi Motors“
