Torque Settings / Drehmoment Tabelle
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Beitrag von bob2.0 »
Introduction;
I have not seen anyone collect torque settings together, and I suggest we do this for e-Odin.
We may or may not know what they are (if you do, please share).
My suggestion is that we use a torque setting that other motorcycles typically use, try that.
If it loosens, then it wasn't enough!
If it is difficult to remove later, it was too tight!
If we explain later in the text why we used it, we can have a discussion, maybe improve the table over time.
I will edit it, if I notice or you drop me a PM. If you think a setting is too high or too low, please do let me know, these are what I am setting my bike to.
Zuletzt geändert von bob2.0 am Mo 28. Okt 2024, 18:56, insgesamt 2-mal geändert.
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Re: Torque Settings / Drehmoment Tabelle
List of Suggested Torque Settings
(Settings as used on members bikes; use your own judgement when using this table on your own bike.)
Fork clamp bolts _______________________ 23 Nm
Front and rear Caliper bracket ___________ 38 Nm
Brake disc ____________________________ 23 Nm
Not otherwise stated (settings not tested on specific parts, use your own judgement):
M5, all metal parts _____________________ 4 Nm
M6, all metal parts _____________________ 10 Nm
M8, all metal parts _____________________ 18 Nm
M5, with plastic parts ___________________ 1 Nm
M6, with plastic parts __________________ 3 Nm
Zuletzt geändert von bob2.0 am Mo 28. Okt 2024, 19:06, insgesamt 5-mal geändert.
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Most bike brake discs are around 12 to 18Nm. When I used 18Nm it seemed too little. The disc that I had not moved seemed to be more than 18 Nm.
Caliper mounts are usually high, I went for 38 Nm, this is normal.
The lower fork bolts were looser than 23 Nm. I had not touched these, but when I tightened them they must have been only 15 Nm or so. I put on about half a turn to bring them to 23 Nm.
Zurück zu „Dayi Motors“
