Alrendo Bravo - Gemeldete Mängel
- Roller: Zero S 2025
- PLZ: 10437
Re: Alrendo Bravo - Gemeldete Mängel
Guten Morgen,
das wurde heute in der Facebook Gruppe Alrendo gepostet. Ich weiß leider nicht wer von uns die erste Serie von Alrendo hat?vorenthalten will ich es trotzdem nicht, da ja sogar gewarnt wird weiterzufahren.
English 25-AUG-2023 message from my dealer
Important notice regarding your Alrendo motorcycle
Dear Alrendo rider
I would like to inform you of a possible serious technical defect on your motorcycle. It has recently become apparent that at one of our Alrendo owners in the BeNeLux the steering column clamping block has come loose due to the breakage of one or more of the fixing screws. This can prevent the motorcycle from becoming uncontrollable because the handlebars are only attached to the Upper Clamp with 1 bolt.
Electric Motorbikes immediately contacted Alrendo Europe and I was told that the aforementioned has already happened once before with an Alrendo TS Bravo driving in France with 35,000 km on the clock. This was completely unknown to me until now.
I believe this calls for an investigation of any Alrendo TS Bravo and may be a manufacturing defect. The bolt may have been overtightened during assembly and was forced.
In addition to informing you as a driver, I will be contacting other suppliers of the Alrendo TS Bravo in Europe as well as Alrendo Europe and Alrendo China (Wuxi Tonma Electric Vehicle Co.Ltd). According to Alrendo Europa, it would only be about the motorcycles from the first series, but what that first series is exactly is unknown to me at the moment.
Because I cannot oversee what this defect means for the other Alrendo TS Bravos supplied by Electric Motorbikes, I want to send you this warning anyway. Together with other experts, I hope to have clarity about the impact of this as soon as possible. Until then, I advise you to travel safely and perhaps not use your Alrendo TS Bravo until further notice.
At the moment, despite several reminders, we do not yet have a usable owners manual and a technical manual. As a result, we do not know, for example, what the exact tightening torques are and we cannot yet communicate them to you.
We will of course keep you informed of the research and further developments.
Dear Alrendo rider
- vaderAT
- Roller: ZERO SR ZF15.6 2023
- PLZ: 8010
alter schwede ... das is ja beinahe schon kriminell!
kenne mich wirklich nicht aus, aber kann man da mit einem anwalt dagegen vorgehen und den schrott zurückschicken gegen rückerstattung der kohle?
- Roller: Alrendo TS Bravo & Bimie Grazie Sport Premio WR5
- PLZ: 1050
Hmm, ich habe wohl eine der ersten in Europa verkauften Alrendos.
Aber willst Du machen? Alrendo-Europe gibt es schon lange nicht mehr, mein Händler hat frustriert das Handtuch geworfen und Alrendo aus dem Sortiment gekickt.
Bleibt nur noch Alrendo-China zu verklagen - glaubst Du ernsthaft, daß das die Chinesen auch nur irgendwie juckt?
- vaderAT
- PLZ: 8010
der meinte ja in dem post dass er ALRENDO EUROPE informiert hat!?
von der HP:
ALRENDO EUROPE
Email: Info@alrendo.com
U Županských 39, 193 00 Praha 20
und wie geschrieben - ich kenne mich da nicht aus.
auf jeden fall würde ich auf gar keinen fall nur einen weiteren meter mit dem dreck fahren ...
von der HP:
ALRENDO EUROPE
- kiezbike
- Roller: AXXTO XX5000DT
- PLZ: 22305
Ich habe es schon in einem anderen Beitrag geschrieben - Alrendo ist jetzt ALRANDOvaderAT hat geschrieben: ↑Sa 26. Aug 2023, 09:55der meinte ja in dem post dass er ALRENDO EUROPE informiert hat!?
von der HP:
ALRENDO EUROPE
- MrGreenwood
- PLZ: 22559
Schon länger bekannt und hier auch schon thematisiert.kiezbike hat geschrieben: ↑Sa 26. Aug 2023, 09:58Ich habe es schon in einem anderen Beitrag geschrieben - Alrendo ist jetzt ALRANDOvaderAT hat geschrieben: ↑Sa 26. Aug 2023, 09:55der meinte ja in dem post dass er ALRENDO EUROPE informiert hat!?
von der HP:
ALRENDO EUROPE
U Županských 39, 193 00 Praha 20![]()
ORA Funky Cat 400 Pro+
Alrendo TS Bravo
Riese & Müller Packster 40 vario HS
Alrendo TS Bravo
- kiezbike
- PLZ: 22305
sendest Du mir mal den LinkMrGreenwood hat geschrieben: ↑Sa 26. Aug 2023, 10:01Schon länger bekannt und hier auch schon thematisiert.kiezbike hat geschrieben: ↑Sa 26. Aug 2023, 09:58Ich habe es schon in einem anderen Beitrag geschrieben - Alrendo ist jetzt ALRANDOvaderAT hat geschrieben: ↑Sa 26. Aug 2023, 09:55der meinte ja in dem post dass er ALRENDO EUROPE informiert hat!?
von der HP:
ALRENDO EUROPE
- MrGreenwood
- PLZ: 22559
Suchfeld: Alrando
Sollte man immer tun, bevor man "Neues" verkünden möchte.
Alrendo TS Bravo
Alrendo TS Bravo
- Rey
- Roller: Alrendo Bravo TS
- PLZ: 012
- Tätigkeit: Fluggerätelektroniker
Das ist schon länger bekannt mit dem Bolzen. Ich würde die jetzt einfach austauschen. Das ist jetzt leider auch nicht so ungewöhnlich
das Zeug getauscht werden muss weil es fehlerhaft ist und gefährlich. Ich erinnere nur an die Ankerbleche bei Hersteller XY die in die Bremsen rutschen können. Airbags die nicht funktionieren und und und.
