Tromox Mino not starting
emyy161
Roller: Tromox Mino 45
PLZ: SS12J
Land: anderes Land
Beitrag von emyy161 »
Hello all,
My friend is having an issue with his Tromox, last week when he finished work, he got on the bike, and the P light was stuck on no matter what he has done. I have checked all the connection, used contact cleaner on the ones that looked a bit dirty, unplugged the side stand and tried to turn it on, cleaned the side stand switch but nothing is working. Has anyone got any ideas on what it could be. The app barely works but it says there is no errors, and also can't do OTA upgrades as it says bluetooth is not connected, there is no battery info, all it can do is start the bike. I have tried starting the bike from the phone to eliminate the battery issue as the key was nowhere nearby and it still didn't work. Thank you in advance for your time and sorry about not being German but this is the only forum I have really found that has info on Tromox bikes :lol:
Re: Tromox Mino not starting
You could check the two brake lever switches. Do they enable/disable the stop light, or does the stop light glow permanent (and block the drive)
Maybe, the vehicle needs a propper "battery OK" information to switch from parking mode to ready mode.
VG
Zurück zu „Tromox“
