Lingbo LBMC HK2A ZWK060050-B-A2 ZNEN ZHEN 12C-260-BS
Schnabelwesen
PLZ: 2411
Re: Lingbo LBMC HK2A ZWK060050-B-A2 ZNEN ZHEN 12C-260-BS
Beitrag von Schnabelwesen »
Sorry, bei mir war natürlich der DC DC Spannungswandler zerschossen, nicht der Controller. Danach hatte Fasemann ja auch gefragt.
szupek
Roller: vionis ksr
Land: anderes Land
Beitrag von szupek »
kamil28 hat geschrieben:
Sa 24. Sep 2022, 20:39
Hi, I need TP8485E, do you still have them? Is the communication possible after soldering this chip on the board?
The same story here, I already ordered some on aliexpress. I am also wondering if after soldering this chip, communication will be available.
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
Beitrag von kamil28 »
szupek hat geschrieben:
So 25. Sep 2022, 10:41
Unfortunately, they are not available in Europe and Aliexpress is the only option :( mine were ordered yesterday, let me know if you were able to establish communication, I'm super curious.
szupek
Roller: vionis ksr
Land: anderes Land
Mine just arrived, I will be trying to solder and establish a communication.
szupek
Roller: vionis ksr
Land: anderes Land
After I soldered the chip, I could not connect like before. @ALDI_Pilot, did you solder anything else except this chip? There are some spots that connect pins 6 and 7 to tx and rx - didn't you put any resitor or shunt there? Now it looks like there is some response from the chip, Rx on my uart flashed, but it cannot be recognized and I end up with timeout or nothung from device message.
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
So 9. Okt 2022, 16:55
Which USB dongle are you using for the connection? Which software?
szupek
Roller: vionis ksr
Land: anderes Land
I used CH340 chip and several pl2303 chips and result was the same.
I used "LBGUI_v120.17.0222" "LBGUI_v121.18.0329" "LBMC GUI v4.0.0" "LB GUI v121.20.2300K3AP for K3AP Controller" "LBMCGuiV3" and also no difference.
I bought logic analyzer to play around with it for a while during winter :)
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
Fr 4. Nov 2022, 21:46
In this case, you should to use RS485 serial communication USB dongle. Are you able to try with this one and let me know if it's working?
szupek
Roller: vionis ksr
Land: anderes Land
Mi 9. Nov 2022, 19:20
Ho do you know of that? Is this confirmed info? BTW, I responded to your PM :)
slash_spb2
PLZ: 1
Beitrag von slash_spb2 »
Hello!
I'm interesting in this theme. Seems there is NIU proprietary protocol with cyphering on RS485 bus. I do some sniffing but data every time different.
Here xample of packets on NIU RS485 bus:
fe fe fe fe 68 20 df 68 01 01 34 05 59 ff
68 20 df 68 81 05 37 44 94 f1
Did you get any result?) I want to try connect to SWD bus of STM, but 90% it will be locked...
Mitglieder in diesem Forum: Vahrland und 7 Gäste
