Rezon Bohemia
bikemite
Händler
Roller: Bimie EFO Hechi HMW Horwin Tailg Trinity
PLZ: 1130
Re: Rezon Bohemia
Beitrag von bikemite »
`Naja es scheint schon so, dass die Bohemia einige Änderungen gegenüber der Alrendo haben wird, die ein neues Modell/einen neuen Bereich rechtfertigen würde. Allein die Dimension und der Rahmen wird wohl gleich bleiben... Aber mal abwarten, wie du geschrieben hast...
Horwin: EK3, SK3, SK3 Plus
Hechhi: Big Boy, E-XDV
HMW: Conn-E
Der craf
PLZ: 67166
Re: Rezon Bohemia
Beitrag von Der craf »
Habe Mail bekommen
Die Vorführer sollen Ende Mai kommen
vaderAT
Roller: ZERO SR ZF15.6 2023
PLZ: 8010
Re: Rezon Bohemia
Beitrag von vaderAT »
We have had a lot of questions about the on-board charging unit fitted to the Rezon Bohemia. It's time we cleared up some information about it.
1. Yes it does charge as both DC and AC chargers
2. The maximum charge speed is 6.6kw when using either DC or AC Charging. The DC charging function is to allow you access to more of the charging network so you will never be stranded. It is completely optional and for riders in certain countries, you'll probably never even need to use it if there's enough AC chargers.
3. The DC charger is simply a larger DC-DC inverter. It's not complicated, it's actually a pretty simple tried and tested technology. It simply steps down 260v to 100v.
4. A 12kw charger is not possible because it is absolutely huge and would not fit inside the frame of the bike. We do sell motorcycles, not cars so size takes a much more important part in our design and limitations.
I hope this clears up all of the questions we have had and gives everyone a better understanding of what we are offering.
vaderAT
PLZ: 8010
Re: Rezon Bohemia
We have had some questions about the brakes fitted to the Rezon Bohemia so lets answer that now. Just like a number of superbike manufacturers, we use Nissin brakes from Japan so you can ride with absolute confidence.
#rezonmotorcycles #Rezon
vaderAT
PLZ: 8010
Re: Rezon Bohemia
bikemite hat geschrieben:
So 7. Apr 2024, 14:49
Wird auch in Wien vorhanden sein. Unser Vorführer wird noch im Mai erwartet, hoffe der Termin hält.
Dann gibts auch Probefahrten. Bestellungen besser erst nach der Probefahrt, Katze im Sack usw ihr wisst schon.
http://www.bikemite.at/Rezon.php?variant-id=538
VG
Arno
hi arno!
schon eine idee/konkrete daten wann es erhältlich sein wird bei euch (zumindest für eine probefahrt)?
thx & lg.
bikemite
Händler
PLZ: 1130
Re: Rezon Bohemia
es wird nun Juni werden mit unserem Vorführer, Genaueres habe ich noch nicht.
Wenn die Rezon Bohemia Zeile in https://www.bikemite.at/termine.html grün ist, dann ist sie verfügbar für Probefahrten ;)
LG
Arno
HMW: Conn-E
vaderAT
PLZ: 8010
Re: Rezon Bohemia
lässiger kalender, danke :!:
HerbyK
PLZ: 72xxx
Re: Rezon Bohemia
Beitrag von HerbyK »
Hab mir mal einen Screenshot erlaubt: vielleicht sollten die Unklarheiten in puncto Reichweite , wenn das Teil gefahren werden kann , auch auf der HP beseitigt werden. Man sieht RW 200km, spricht von echten 260km , die laut Ducatodriver im März auf Tempo 45 km/h eingeschränkt wurden....
realistisch wäre , wenn ich schon soviel ausgeben könnte, käme ich mit ihr zur cousine nach HD in xx std?., also:
tempomat bei 120 rein, in A auf eine hügelige BAB und FAHREN... :D
bikemite
Händler
PLZ: 1130
Re: Rezon Bohemia
Wenn wir unseren Vorführer bei uns haben, mache ich sicher ausgiebige Reichweitentests auf der Überland-Straße. I promise. 8-)
HMW: Conn-E
