Open Source Silence Server Project! :)
S01, S02, S03, Mó
Pfriemler
PLZ: 14513
Tätigkeit: Tonkünstler
Re: Open Source Silence Server Project! :)
Beitrag von Pfriemler »
Amazing! 8-)
I will test it ASAP (but give me a few days, there's a lot of other work to do before).
SpeedCore
Roller: Silence S01
PLZ: 6020
Beitrag von SpeedCore »
Thanks for the project! I cloned it on my Raspi, forwarded the port to it and configured the $IPAD and $PORT in the Astra module and also see the module sending the data to the correct ip and port, but the script output doesn't show any incoming traffic (should it do that?) I have a static public ip address.
lorenzo.deluca
Roller: Silence S01
PLZ: ITA
Land: anderes Land
Beitrag von lorenzo.deluca »
SpeedCore hat geschrieben:
Mi 29. Mai 2024, 19:00
Good job ;)
yes, you should see a message like this:
" [SilenceServerService] - INFO - client ('scooter-ip', random-port) connected "
Are you sure you forwarded the port correctly? there are no firewalls in the way? Is the configured port on the module 31337?
SpeedCore
Roller: Silence S01
PLZ: 6020
My bad, had a typo in the port forwarding :roll:
Looking good now!
Code: Alles auswählen
Python version: 3.11.2
Silence-Server version: 2024.5.21
Silence-Server - Main Start
Silence-Server Main
Configuration loaded: (...)
2024-05-29 21:40:17,446 - [silence-server] - DEBUG - Logged configured
2024-05-29 21:40:17,447 - [silence-server] - INFO - Starting Silence Server
2024-05-29 21:40:17,447 - [SilenceServerService] - INFO - Starting SilenceServerService
2024-05-29 21:40:17,447 - [SilenceServerService] - INFO - Starting DBService
2024-05-29 21:40:17,447 - [DBService] - DEBUG - DBService init
2024-05-29 21:40:17,447 - [DBService] - INFO - DBService Start
2024-05-29 21:40:17,448 - [DBService] - DEBUG - Subscribing to socket
2024-05-29 21:40:17,448 - [CommandService] - DEBUG - CommandService init
2024-05-29 21:40:17,448 - [CommandService] - DEBUG - Subscribing to command_received
2024-05-29 21:40:17,449 - [CommandService] - INFO - CommandService Started
2024-05-29 21:40:17,449 - [silence-server] - INFO - Silence Server Started...!
2024-05-29 21:40:17,449 - [SilenceServerService] - INFO - socket created on port 31337
2024-05-29 21:40:17,449 - [SilenceServerService] - INFO - waiting for clients
2024-05-29 21:41:11,291 - [SilenceServerService] - INFO - client ('195.226.***.***', 41229) connected
2024-05-29 21:41:11,292 - [SilenceServerService] - INFO - client connnected: 0
2024-05-29 21:41:11,877 - [SilenceServerService] - INFO - receive data bytearray(b'$ASTRA;AT402;8608730********;;7.0.68.35;Z;0\r\n')
2024-05-29 21:41:11,878 - [DBService] - DEBUG - Received message from A: bytearray(b'$ASTRA;AT402;8608730********;;7.0.68.35;Z;0\r\n')
2024-05-29 21:41:12,106 - [SilenceServerService] - INFO - retrieved IMEI: 8608730********
2024-05-29 21:41:12,106 - [SilenceServerService] - INFO - bridge mode, try to connect to Silence server
2024-05-29 21:41:12,523 - [SilenceServerService] - INFO - connected to silence
2024-05-29 21:41:13,063 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
2024-05-29 21:41:13,063 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
2024-05-29 21:41:23,078 - [SilenceServerService] - INFO - login correct sending ack
2024-05-29 21:41:31,212 - [SilenceServerService] - INFO - receive data bytearray(b"Z\x00^\x01\(...)
2024-05-29 21:41:31,418 - [SilenceServerService] - INFO - sent to silence
2024-05-29 21:41:36,375 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
2024-05-29 21:41:36,375 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
2024-05-29 21:41:36,580 - [SilenceServerService] - INFO - sent to scooter the data from silence bytearray(b'\x06')
2024-05-29 21:41:38,382 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:41:53,601 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:42:08,819 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:42:24,038 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:42:39,255 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:42:54,474 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:43:09,692 - [SilenceServerService] - INFO - sent ack to scooter
lorenzo.deluca
Roller: Silence S01
PLZ: ITA
Land: anderes Land
Mi 29. Mai 2024, 21:44
My bad, got a typo in the port forwarding :roll:
Looking good now!
Silence-Server Main
Great! Do you see data on MQTT? If you use Home Assistant I can provide yaml configuration for status and commands.
SpeedCore
Roller: Silence S01
PLZ: 6020
I have MQTT disabled in the config for now. I don't have home assistant running, but all my smart home devices running in homebridge. I already found a plugin called "mqttthings" and currently trying to figure out if that could be useful in integrating the scooter in homebridge. Since I've had quite some troubles with homebridge, maybe this could be the moment to switch to home assistant :D
Gerold
Roller: Silence S01
PLZ: 55*
Beitrag von Gerold »
I get the following results on my ubuntu server:
Python version: 3.12.3
Silence-Server Main
Configuration loaded: {'IMEI': '35xxxxxx', 'TCPServer': {'serverPORT': 31090, 'bridgeMode': True, 'silenceHOST': 'api.connectivity.silence.eco', 'silencePORT': 38955, 'SaveToDB': True, 'keepAliveInterval': 15, 'BMScellVoltage_pooling_interval': 600}, 'Logging': {'LogToFile': True, 'LogLevel': 50}, 'MQTT': {'Enabled': True, 'MQTTbroker': '192.xxx.xxx.xx', 'MQTTport': 1883, 'MQTTuser': 'xxx', 'MQTTpass': 'xxxx', 'TopicPrefix': 'mySilence'}}
2024-05-29 21:20:34,535 - [silence-server] - DEBUG - Logged configured
2024-05-29 21:20:34,535 - [silence-server] - INFO - Starting Silence Server
2024-05-29 21:20:34,535 - [SilenceServerService] - INFO - Starting SilenceServerService
2024-05-29 21:20:34,535 - [SilenceServerService] - INFO - Starting DBService
2024-05-29 21:20:34,535 - [DBService] - DEBUG - DBService init
2024-05-29 21:20:34,535 - [DBService] - INFO - DBService Start
2024-05-29 21:20:34,536 - [DBService] - DEBUG - Subscribing to socket
2024-05-29 21:20:34,537 - [CommandService] - DEBUG - CommandService init
2024-05-29 21:20:34,537 - [CommandService] - DEBUG - Subscribing to command_received
2024-05-29 21:20:34,538 - [CommandService] - INFO - CommandService Started
2024-05-29 21:20:34,538 - [silence-server] - INFO - Starting MQTT
2024-05-29 21:20:34,538 - [MQTTService] - DEBUG - MQTT Service initialized
2024-05-29 21:20:34,539 - [MQTTService] - INFO - Start MQTT Service
2024-05-29 21:20:34,539 - [SilenceServerService] - INFO - socket created on port 31090
2024-05-29 21:20:34,539 - [SilenceServerService] - INFO - waiting for clients
2024-05-29 21:20:34,542 - [MQTTService] - DEBUG - Pub/Sub on scooter_status
2024-05-29 21:20:34,543 - [MQTTService] - DEBUG - Pub/Sub on command_result
2024-05-29 21:20:34,544 - [silence-server] - INFO - Silence Server Started...!
2024-05-29 21:20:34,546 - [MQTTService] - INFO - Connected to broker with result code 0
2024-05-29 21:20:34,546 - [MQTTService] - DEBUG - MQTT Sub to mySilence/35xxxx/command/+
2024-05-29 21:20:38,415 - [SilenceServerService] - INFO - client ('195.226.133.37', 6262) connected
2024-05-29 21:20:38,415 - [SilenceServerService] - INFO - client connnected: 0
2024-05-29 21:20:39,109 - [SilenceServerService] - INFO - receive data bytearray(b'$ASTRA;SL240V8;35xxxxx;;7.0.70.35;Z;8\r\n')
2024-05-29 21:20:39,109 - [DBService] - DEBUG - Received message from A: bytearray(b'$ASTRA;SL240V8;35xxxxx;;7.0.70.35;Z;8\r\n')
2024-05-29 21:20:39,315 - [SilenceServerService] - INFO - retrieved IMEI: 35xxxxxx
2024-05-29 21:20:39,316 - [SilenceServerService] - INFO - bridge mode, try to connect to Silence server
2024-05-29 21:20:39,333 - [SilenceServerService] - INFO - connected to silence
2024-05-29 21:20:39,348 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
2024-05-29 21:20:39,348 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
2024-05-29 21:20:49,364 - [SilenceServerService] - INFO - login correct sending ack
2024-05-29 21:21:04,388 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:21:19,614 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:21:34,839 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:21:50,066 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:22:05,291 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:22:20,517 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:22:35,742 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:22:50,968 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:23:06,194 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:23:15,353 - [SilenceServerService] - INFO - receive data bytearray(b'Z\x00b\x01\xb8\x00\x01\x00\x00\x00/S\x82C"\x00\x00\x00\x01\x00\x08>ZS\x82C!\x02\xfa\x9c\xf6\x00}\x06\x85\x00\x00\x03\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01{N\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00\tr')
2024-05-29 21:23:15,353 - [DBService] - DEBUG - Received message from A: bytearray(b'Z\x00b\x01\xb8\x00\x01\x00\x00\x00/S\x82C"\x00\x00\x00\x01\x00\x08>ZS\x82C!\x02\xfa\x9c\xf6\x00}\x06\x85\x00\x00\x03\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01{N\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00\tr')
2024-05-29 21:23:15,560 - [SilenceServerService] - INFO - received status from scooter
2024-05-29 21:23:15,560 - [messageParser] - DEBUG - Parse received message protocol Z from scooter: bytearray(b'Z\x00b\x01\xb8\x00\x01\x00\x00\x00/S\x82C"\x00\x00\x00\x01\x00\x08>ZS\x82C!\x02\xfa\x9c\xf6\x00}\x06\x85\x00\x00\x03\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01{N\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00\tr')
2024-05-29 21:23:15,560 - [messageParser] - DEBUG - Message protocol Z parsed: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:23:15,560 - [MQTTService] - DEBUG - Publishing scooter status: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/motorTemp] value: None
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/inverterTemp] value: None
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/speed] value: None
2024-05-29 21:23:15,562 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/ambientTemp] value: None
2024-05-29 21:23:15,562 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/last-update] value: 1717010595.562439
2024-05-29 21:23:15,562 - [SilenceServerService] - INFO - sent to silence
2024-05-29 21:23:15,578 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
2024-05-29 21:23:15,578 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
2024-05-29 21:23:15,785 - [SilenceServerService] - INFO - sent to scooter the data from silence bytearray(b'\x06')
2024-05-29 21:23:21,195 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:23:36,421 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:23:51,647 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:24:06,873 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:24:22,099 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:24:37,324 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:24:52,551 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:25:07,777 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:25:23,003 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:25:38,230 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:25:53,456 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:25:59,065 - [SilenceServerService] - INFO - receive data bytearray(b'$STMS')
2024-05-29 21:25:59,066 - [DBService] - DEBUG - Received message from S: bytearray(b'$STMS')
2024-05-29 21:25:59,072 - [SilenceServerService] - INFO - sent to scooter the data from silence bytearray(b'$STMS')
2024-05-29 21:26:00,675 - [SilenceServerService] - INFO - receive data bytearray(b'$STMS,0,78,20,20,549,0,4207,0,0,0,0,0,67,0,2416024,136134,2256375,21,08xxxxx,+8xxxxxxx,UCYS01300xxxxxxx\r\n')
2024-05-29 21:26:00,676 - [DBService] - DEBUG - Received message from A: bytearray(b'$STMS,0,78,20,20,549,0,4207,0,0,0,0,0,67,0,2416024,136134,2256375,21,08xxxxxx,+8xxxxxxx,UCYS01300xxxxxx\r\n')
2024-05-29 21:26:00,882 - [SilenceServerService] - INFO - received status from scooter
2024-05-29 21:26:00,882 - [messageParser] - DEBUG - Parse received message protocol astra from scooter: bytearray(b'$STMS,0,78,20,20,549,0,4207,0,0,0,0,0,67,0,2416024,136134,2256375,21,08xxxxxxx,+8xxxxx,UCYS01300xxxxx\r\n')
2024-05-29 21:26:00,882 - [messageParser] - DEBUG - Message protocol astra parsed: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:26:00,882 - [MQTTService] - DEBUG - Publishing scooter status: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:26:00,882 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/motorTemp] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/inverterTemp] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxx/status/speed] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/ambientTemp] value: None
2024-05-29 21:26:00,884 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/last-update] value: 1717010760.8841224
2024-05-29 21:26:00,884 - [SilenceServerService] - INFO - sent to silence
2024-05-29 21:26:08,497 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:26:23,722 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:26:38,948 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:26:54,173 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:27:09,399 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:27:24,626 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:27:39,852 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:27:55,078 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:28:10,305 - [SilenceServerService] - INFO - sent ack to scooter
2024-05-29 21:28:15,315 - [SilenceServerService] - INFO - receive data bytearray(b'Z\x00b\x01\xb9\x00\x01\x00\x00\x00/S\x82DN\x00\x00\x00\x01\x00\x08>ZS\x82DM\x02\xfa\x9c\xfe\x00}\x06z\x00\x00\xa9\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01mN\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00;t')
2024-05-29 21:28:15,315 - [DBService] - DEBUG - Received message from A: bytearray(b'Z\x00b\x01\xb9\x00\x01\x00\x00\x00/S\x82DN\x00\x00\x00\x01\x00\x08>ZS\x82DM\x02\xfa\x9c\xfe\x00}\x06z\x00\x00\xa9\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01mN\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00;t')
2024-05-29 21:28:15,521 - [SilenceServerService] - INFO - received status from scooter
2024-05-29 21:28:15,521 - [messageParser] - DEBUG - Parse received message protocol Z from scooter: bytearray(b'Z\x00b\x01\xb9\x00\x01\x00\x00\x00/S\x82DN\x00\x00\x00\x01\x00\x08>ZS\x82DM\x02\xfa\x9c\xfe\x00}\x06z\x00\x00\xa9\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01mN\x14\x14\x02%\x00\x00\x00\x00\x10o\x00\x00\x00\x00\x00\x00\x00C\x00\x00\x00\x00\x00$\xdd\x98\x00\x02\x13\xc6\x00"m\xf7\x15\x00\x00\x00(\xf9\x00\x00\x00\x00\x00;t')
2024-05-29 21:28:15,522 - [messageParser] - DEBUG - Message protocol Z parsed: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:28:15,522 - [MQTTService] - DEBUG - Publishing scooter status: {'status': {'value': None, 'MQTT_topic': 'status'}, 'movementAlarm': {'value': None, 'MQTT_topic': 'movementAlarm'}, 'batteryIn': {'value': None, 'MQTT_topic': 'batteryIn'}, 'astraBatterySOC': {'value': None, 'MQTT_topic': 'astraBatterySOC'}, 'latitude': {'value': None, 'MQTT_topic': 'latitude'}, 'longitude': {'value': None, 'MQTT_topic': 'longitude'}, 'batterySOC': {'value': None, 'MQTT_topic': 'SOCbatteria'}, 'batteryTempMax': {'value': None, 'MQTT_topic': 'BatteryTempMax'}, 'batteryTempMin': {'value': None, 'MQTT_topic': 'BatteryTempMin'}, 'batteryVoltage': {'value': None, 'MQTT_topic': 'VOLTbatteria'}, 'batteryCurrent': {'value': None, 'MQTT_topic': 'batteryCurrent'}, 'motorTemp': {'value': 'None', 'MQTT_topic': 'motorTemp'}, 'inverterTemp': {'value': 'None', 'MQTT_topic': 'inverterTemp'}, 'speed': {'value': 'None', 'MQTT_topic': 'speed'}, 'range': {'value': None, 'MQTT_topic': 'range'}, 'chargedEnergy': {'value': None, 'MQTT_topic': 'chargedEnergy'}, 'RegeneratedEnergy': {'value': None, 'MQTT_topic': 'RegeneratedEnergy'}, 'DischargedEnergy': {'value': None, 'MQTT_topic': 'DischargedEnergy'}, 'ambientTemp': {'value': 'None', 'MQTT_topic': 'ambientTemp'}, 'odo': {'value': None, 'MQTT_topic': 'odo'}, 'VIN': {'value': None, 'MQTT_topic': 'VIN'}, 'Cell1Voltage': {'value': None, 'MQTT_topic': 'Cell1Voltage'}, 'Cell2Voltage': {'value': None, 'MQTT_topic': 'Cell2Voltage'}, 'Cell3Voltage': {'value': None, 'MQTT_topic': 'Cell3Voltage'}, 'Cell4Voltage': {'value': None, 'MQTT_topic': 'Cell4Voltage'}, 'Cell5Voltage': {'value': None, 'MQTT_topic': 'Cell5Voltage'}, 'Cell6Voltage': {'value': None, 'MQTT_topic': 'Cell6Voltage'}, 'Cell7Voltage': {'value': None, 'MQTT_topic': 'Cell7Voltage'}, 'Cell8Voltage': {'value': None, 'MQTT_topic': 'Cell8Voltage'}, 'Cell9Voltage': {'value': None, 'MQTT_topic': 'Cell9Voltage'}, 'Cell10Voltage': {'value': None, 'MQTT_topic': 'Cell10Voltage'}, 'Cell11Voltage': {'value': None, 'MQTT_topic': 'Cell11Voltage'}, 'Cell12Voltage': {'value': None, 'MQTT_topic': 'Cell12Voltage'}, 'Cell13Voltage': {'value': None, 'MQTT_topic': 'Cell13Voltage'}, 'Cell14Voltage': {'value': None, 'MQTT_topic': 'Cell14Voltage'}}
2024-05-29 21:28:15,522 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/motorTemp] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxxstatus/inverterTemp] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/speed] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/ambientTemp] value: None
2024-05-29 21:28:15,524 - [MQTTService] - DEBUG - Publishing on topic [mySilence/35xxxxx/status/last-update] value: 1717010895.5240157
2024-05-29 21:28:15,524 - [SilenceServerService] - INFO - sent to silence
2024-05-29 21:28:15,925 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
2024-05-29 21:28:15,925 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
Maybe there is a problem with the parser.
Zuletzt geändert von Gerold am Do 30. Mai 2024, 22:20, insgesamt 1-mal geändert.
SpeedCore
Roller: Silence S01
PLZ: 6020
I quickly set up mosquitto on my Raspi and I also see that it's publishing the scooter's values on the topics:
2024-05-29 22:21:03,808 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/status] value: 0.0
2024-05-29 22:21:03,808 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/movementAlarm] value: 0
2024-05-29 22:21:03,808 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/batteryIn] value: 1
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/astraBatterySOC] value: 97.0
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/latitude] value: 47.******
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/longitude] value: 11.******
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/SOCbatteria] value: 35.0
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/BatteryTempMax] value: 20.0
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/BatteryTempMin] value: 19.0
2024-05-29 22:21:03,809 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/VOLTbatteria] value: 51.1
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/batteryCurrent] value: 0.0
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/motorTemp] value: None
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/inverterTemp] value: None
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/speed] value: None
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/range] value: 36.0
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/chargedEnergy] value: 121.27666666666667
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/RegeneratedEnergy] value: 6.298333333333333
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/DischargedEnergy] value: 109.98694444444445
2024-05-29 22:21:03,810 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/ambientTemp] value: None
2024-05-29 22:21:03,811 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/odo] value: 5944.0
2024-05-29 22:21:03,811 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/last-update] value: 1717014063.8112075
I also set up a quick systemd service (/etc/systemd/system/silence-server.service ) for better handling:
[Unit]
Description=Silence Private Server
After=network.target
StartLimitIntervalSec=0
[Service]
Type=simple
Restart=always
RestartSec=1
User=YOURUSER
WorkingDirectory=/home/YOURUSER/silence-private-server
ExecStart=/home/YOURUSER/silence-private-server/python3-silence/bin/python3 /home/YOURUSER/silence-private-server/silence-server.py
[Install]
WantedBy=multi-user.target
Please note that I cloned the repo in my home dir and created a venv for python3, so your directories could vary.
sudo systemctl status silence-server
● silence-server.service - Silence Private Server
     Loaded: loaded (/etc/systemd/system/silence-server.service; enabled; preset: enabled)
     Active: active (running) since Wed 2024-05-29 23:22:07 CEST; 9min ago
   Main PID: 328302 (python3)
      Tasks: 6 (limit: 9262)
        CPU: 410ms
     CGroup: /system.slice/silence-server.service
             └─328302 /home/***/silence-private-server/python3-silence/bin/python3 /home/***/silence-private-server/silence-server.py
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,227 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/ambientTemp] value: None
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,227 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/odo] value: 5944.0
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,227 - [MQTTService] - DEBUG - Publishing on topic [home/silence-server/8608730********/status/last-update] value: 1717018265.2272038
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,227 - [SilenceServerService] - INFO - sent to silence
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,252 - [SilenceServerService] - INFO - receive data bytearray(b'\x06')
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,252 - [DBService] - DEBUG - Received message from S: bytearray(b'\x06')
May 29 23:31:05 homebridge python3[328302]: 2024-05-29 23:31:05,457 - [SilenceServerService] - INFO - sent to scooter the data from silence bytearray(b'\x06')
May 29 23:31:06 homebridge python3[328302]: 2024-05-29 23:31:06,058 - [SilenceServerService] - INFO - sent ack to scooter
May 29 23:31:21 homebridge python3[328302]: 2024-05-29 23:31:21,276 - [SilenceServerService] - INFO - sent ack to scooter
May 29 23:31:36 homebridge python3[328302]: 2024-05-29 23:31:36,487 - [SilenceServerService] - INFO - sent ack to scooter
lorenzo.deluca
Roller: Silence S01
PLZ: ITA
Land: anderes Land
Mi 29. Mai 2024, 22:29
[Unit]
[Service]
Type=simple
Restart=always
RestartSec=1
User=YOURUSER
[Install]
        CPU: 410ms
Seems perfect, Honestly, I prefer Docker, on repo there's Dockerfile, you can build and run in docker without any python or service configuration ;)
I recommend you take the ‘big step’ to Home Assistant!
It opens up an infinite world of automations, integrations, etc.. then you can expose devices from HA to Homebridge for native use on iOS, etc..
lorenzo.deluca
Roller: Silence S01
PLZ: ITA
Land: anderes Land
Gerold hat geschrieben:
Mi 29. Mai 2024, 22:00
Silence-Server Main
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/motorTemp] value: None
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/inverterTemp] value: None
2024-05-29 21:23:15,561 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/speed] value: None
2024-05-29 21:23:15,562 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/ambientTemp] value: None
2024-05-29 21:23:15,562 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/last-update] value: 1717010595.562439
2024-05-29 21:26:00,882 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/motorTemp] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/inverterTemp] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/speed] value: None
2024-05-29 21:26:00,883 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/ambientTemp] value: None
2024-05-29 21:26:00,884 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/last-update] value: 1717010760.8841224
2024-05-29 21:28:15,522 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/motorTemp] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/inverterTemp] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/speed] value: None
2024-05-29 21:28:15,523 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/ambientTemp] value: None
2024-05-29 21:28:15,524 - [MQTTService] - DEBUG - Publishing on topic [mySilence/358887095147581/status/last-update] value: 1717010895.5240157
Strange... do you have Seat or Silence S01? Have you try to open Silence/Seat App and force update?
Zurück zu „Silence / SEAT“
Mitglieder in diesem Forum: Dot [Bot], ducatodriver, Herve21, martr84 und 7 Gäste
