oder bei alten mopeds
Code: Alles auswählen
07218 0 Calex 720W Charger 0 Connected
07219 0 Calex 1200W Charger 1 Connected
07220 0 DEBUG: Module scheme changed from None mode to Charging mode
07221 0 Module 00 vmod: 0V, batt curr: 0A
07222 0 Module 01 vmod: 0V, batt curr: 0A
07223 0 Module 00 CAN Link Up
07224 0 Module 01 CAN Link Up
07225 1 Module 00 serial: 19lb1000, vmod: 100.933V
07226 10/12/2024 07:50:24 Sevcon Turned On
07227 10/12/2024 07:50:24 Module 01 serial: 17sg0418, vmod: 100.929V
07228 10/12/2024 07:55:52 Sevcon CAN Link Up
07229 10/12/2024 07:55:52 Sevcon not ready to be checked for 11kW, Disabling Bike until a battery has connected and we can check the sevcon
07230 10/12/2024 07:55:54 Contactor Welded
07231 10/12/2024 07:55:54 Sevcon Turned Off
07232 10/12/2024 07:55:55 Sevcon Turned On
07233 10/12/2024 07:55:56 Sevcon CAN Link Up
07234 10/12/2024 07:55:57 Sevcon not ready to be checked for 11kW, Disabling Bike until a battery has connected and we can check the sevcon
07235 10/12/2024 07:55:58 Contactor Welded
07236 10/12/2024 07:55:58 Sevcon Turned Off
07237 10/12/2024 07:56:00 Sevcon Turned On
07238 10/12/2024 07:56:01 Sevcon CAN Link Up
07239 10/12/2024 07:56:01 Sevcon not ready to be checked for 11kW, Disabling Bike until a battery has connected and we can check the sevcon
07240 10/12/2024 07:56:01 DEBUG: Sevcon Contactor Drive ON.
07241 10/12/2024 07:56:01 Charging PackTemp: h 8C, l 7C, AmbTemp:535C, PackSOC: 37%, Vpack:100.923V, BattAmps: 0, Mods: 00, MbbChgEn: Yes, BmsChgEn: No
07242 10/12/2024 07:56:01 Module 00 vmod: 100.929 maxsys: 100.929 minsys: 100.875 diff: 0.054 vcap: 91.875 prechg: 91%
07243 10/12/2024 07:56:01 Controller was already setup for 11kW
07244 10/12/2024 07:56:01 Module 01 vmod: 100.891 maxsys: 100.983 minsys: 100.891 diff: 0.092 vcap: 100.062 prechg: 99%
07245 10/12/2024 07:56:01 DEBUG: Module 00 Contactor is now Closed
07246 10/12/2024 07:56:01 INFO: Enabling Calex 720W Charger 0
07247 10/12/2024 07:56:01 INFO: Enabling Calex 1200W Charger 1
07248 10/12/2024 07:56:01 INFO: Enabling External Chg 0 Charger 2
07249 10/12/2024 07:56:02 INFO: Enabling External Chg 1 Charger 3
07250 10/12/2024 07:56:02 DEBUG: Module 01 Contactor is now Closed
Mitglieder in diesem Forum: matzi1009 und 31 Gäste
