Verkäufer Kunden NMD24
Miguello80
Roller: E-Odin 2.0 6kW AMR
Land: anderes Land
Re: Verkäufer Kunden NMD24
Beitrag von Miguello80 »
zherom hat geschrieben:
Fr 13. Sep 2024, 08:07
yes i mean those 2 anoying beeps.
Check this: https://www.youtube.com/watch?v=Xo-DFLB-xfM
Two beeps after the breaker is turned on again is another thing but I do not do it so often to need to solve it.
On top of that, emitted eOdin quietly beeps since last ride, meanwhile for 2 days :‘-(
If you are sure that the sound is not from controller (beeping is used as a flashing the error code) then it seems like some fault on alarm side. I would check connectors and alarm itself, moisture is a bitch. If you do not need it, unplug it. If you need it and can not find a problem, I am affraid that new alarm is the way, luckily they are pretty cheap (as they are pretty crappy).
zherom
Roller: Venaxio6000
PLZ: 8
Beitrag von zherom »
Thanks. Watched youtube. Pretty neat hack. I would't do that. I would rather do it programmatically, if not can live with it, rather as take risk to damage connector...
After Motocycle is turned on, there are no bips :) So the controller must be ok.
Quitly bips after key is removed are unsettling.
I gues you are right about alarm.
I would like to remove this crap. Not found it so far
Btw. my eRoller was exposed only once to very light rain for about 30min.
Miguello80
Land: anderes Land
Di 17. Sep 2024, 15:15
I do not understand how would you do it "programmatically" when alarm is only an unprogrammable stupid box.
Damaging connector ??? Man, you would have to use a hammer + fire to damage it :) If you are affraid of this little thing, you are on right way - two years maintaining E-Odin and you can apply for a work in a motorcycle service business :)
Take off the seat and you will see it. Unplug two connectors and you are alarm-free :) Test the bike without alarm, when beeping is gone, it is a faulty alarm. Get new one on Aliexpress or live without it.
By the way - did you mess with controllers settings like antitheft etc. ?
Once I experienced weird thing - I stopped, get off the bike, let it on, get on a continue riding and bike started to beep, like antitheft (that I did not activated). After I stopped and turned it off and on again it was ok. Mystery... :)
zherom
Roller: Venaxio6000
PLZ: 8
beeping stopped. Some connector was not tight enough. After tightening all of them there is only double beep after key is removed. All is back to normal now.
Yes i will at some point remove this annoying alarm altogether. But not just yet :)
Never change a riding system :D
royoliver
Roller: E-bike
PLZ: 03449
Land: anderes Land
Beitrag von royoliver »
Regards. viewed YouTube. It's a pretty good hack. That is not what I would do. If possible, I would prefer to do it programmatically rather than risk damaging the connector.
Miguello80 hat geschrieben:
Fr 13. Sep 2024, 11:30
Check this: https://www.youtube.com/watch?v=Xo-DFLB-xfMBlock Blast
Miguello80
Land: anderes Land
royoliver hat geschrieben:
Mo 3. Mär 2025, 10:53
Again, it is not possible to program the alarm, it is very simple device. Yes, you can buy something better, even with display on the keychain, just much more expensive.
Damaging the connector... It depends how brutal would you be :) Take a small screwdriver and losen the wire, it is reversible with no damage at all. Even when you do damage anything - connector or wire - it is very simple to repair, you would just connect wires and that is all.
I respect that not everybody is familiar with bikes or cars or wires or any craftwork etc., but as you already know, any bike/car etc. needs maintenance so you can choose to pay somebody to do it or to do it by yourself for much cheaper + have a great feeling of good job. This forum is full of people that will help you, encourage you and guide you if you want, so as there is plenty of Youtube videos about bike maintenance. Get stuck on a simple wire does not fit to E-Odin (or any bike etc.). But of course it is up to you.
faddl92
Roller: Venaxxio V6000 130Ah
PLZ: 97357
Beitrag von faddl92 »
hat noch jemand einen Kontakt zu NMD24? ich kann leider niemanden erreichen und stehe vor folgendem Problem:
-ich habe bei meinem Moped die "besseren" Reifen bestellt (VA: 120/70 17 58W, statt 110/70 17 54P) - es ist auch nur die eine eingetragen
-mein Moped wurde mit einer verzogenen Bremsscheibe geliefert
-Nach einer Weile wurde mir der vordere Reifen inkl. Felge getauscht. Mir wurde ein 110/70 Reifen inkl. Felge geliefert & die alte Felge haben sie mitgenommen.
Problem: In meinem Fahrzeugschein steht nur die 120/70
Steigerung zum Problem: Die Felge auf dem 110/70 ist ne 17x3,0 - die auf dem 120x70 eine 17x3,5
--> ich kann nicht einmal einen neuen Reifen kaufen und einfach auf die Felge montieren, weil die Felge nicht zum Reifen passt...
hat da jemand einen Vorschlag, wie ich weiter vorgehen kann?
Der logisch Weg wäre Kontakt zum Händler, aber da geht niemand ran (vielleicht gibts aktuellere Daten?)
Vielen Dank im Voraus!!!
Liebe Grüße Faddl
Liebe Grüße
Faddl
Afunker
PLZ: 66955
Beitrag von Afunker »
faddl92 hat geschrieben:
Mo 17. Mär 2025, 16:11
.... und stehe vor folgendem Problem:
Liebe Grüße Faddl
FaddI,
das klingt nach dem Problem, wie ich es in einem anderen Tread hier im Forum unter Rechtliches, mal anklingen liess...:
viewtopic.php?f=34&t=43384
Hinzu kommt bei dir, dass die Felgendimension (nicht nur die Reifen) in der BE bzw. der Zulassung stehen.
Bei so etwas, sollte man mal beim TÜV vorsprechen und prüfen lassen, ob eine andere Felge mit anderem Reifen montiert werden darf?!
Dann könnte die Felgengrösse und Reifengrösse (egal welcher Hersteller) vom TÜV abgenommen und von der Zulassungsstelle eingetragen werden.
Dann solltest du aus der Nr. raus sein....
Bleibt die Frage vorweg: Musst du unbedingt bei NMD24 nach der Felge fragen?
Geht nicht auch ein Händler deiner Marke? Oder eine andere Felge von einem Händler von Reifen und Felgen für Motorräder z.B. Euromaster?
Gruss Helmut
Zimmermännche
Roller: E Odin 10kw Typ2
PLZ: 555
Beitrag von Zimmermännche »
Liebe Grüße Faddl
Hallo faddi ich habe mir meine Odin damals auch direkt mit den besseren MAXXIS -Reifen konfiguriert und liefern lassen. Das ist dann auch der 120er Reifen mit 17x3,5, steht so dann auch in den COC-Papieren(siehe Bild), statt des 110er (dass die Felge bei den 110er Reifen 17x3 ist wusste ich jetzt nicht).
Ich weiß nicht ob es nmd24 noch gibt und die irgendwie erreichbar sind, man hat ja auch viel schlechtes darüber im Forum gelesen.
Meine habe ich vom Madatshop, Kommunikation ist da auch nicht einfach. Den gibt es aber noch und soweit ich mich erinnern kann hat der sowohl die Standard Feiben Reifen, wie auch die MAXXIS Reifen (als Ersatzteile) aufgeführt.
Vielleicht kann der ja auch die passende Felge organisieren, die aufgeführte Felge beim Madatshop wird dann wohl auch nur die Standardfelge für den 110er Reifen sein.
E-Odin 3.0S 12/2022
faddl92
PLZ: 97357
Vielen Dank für die Antworten!
@Afunker:
es müsste nicht NMD24 sein, aber wenn die meine 17x3,5" Felge mitgenommen haben und gegen die 17x3,0" Felge getauscht haben, liegt sie vielleicht ja noch im Lager und ich kann sie unkompliziert zurück-tauschen. Ich denke, die Jungs haben das mit der 3,5" Felge einfach nicht gewusst..
Andernfalls werde ich mich nach anderen Lieferanten (Madata...) umschauen
@Zimmermännche:
DU hast sicher eine 17x3,5" Felge drauf? Ich würde dem Hersteller auch zutrauen, dass generell 17x3" verbaut werden... Das ist dann auch gut zu wissen.
Liebe Grüße
Faddl
Zurück zu „Dayi Motors“
Mitglieder in diesem Forum: Volker123 und 16 Gäste
