Tromox Mino
Nickster
Roller: Tromox Mino-B
PLZ: 6900
Land: anderes Land
Re: Tromox Mino
Beitrag von Nickster »
I have been searching for a while now!
Where did you find the LB GUI v121.20.2300?
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Beitrag von vlad_vy »
deadropine hat geschrieben:
So 16. Okt 2022, 19:37
@vlad_vy
I cannot attach the software in the forum but you will find the software in this dropbox:
https://www.dropbox.com/sh/2yuly30y734x ... tracking=1
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Ich habe die CR2450-Batterie auf der Fernbedienung ausgetauscht. Ursache: Die Anerkennung der Fernbedienung ist instabil.
DKtromox
Roller: Tromox
PLZ: 4760
Land: anderes Land
Re: Tromox Mino
Beitrag von DKtromox »
vlad_vy hat geschrieben:
Di 4. Okt 2022, 06:39
deadropine,
Just got USB-RS485 (CH340) adapter. LB GUI 4.00 do not work for me also. Now I use LB GUI v121.20.2300. Controller software version is v121, so the last working version LB GUI will be v121.20.2300.
Is there anybody who can upload a picture of your physical connection with the control unit?
DKtromox
Roller: Tromox
PLZ: 4760
Land: anderes Land
Re: Tromox Mino
What is the maximum performance you can get out of the OEM Tromox Controller?
Which parameters can be changed in the OEM Tromox Controller?
Screenshots of performance enhancing settings in the original OEM Tromox Controller?
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
DKtromox
Roller: Tromox
PLZ: 4760
Land: anderes Land
Re: Tromox Mino
Every time i try to disable the speed limit, and press upload, it comes back on as enable? Am i doing anything wrong?
DKtromox
Roller: Tromox
PLZ: 4760
Land: anderes Land
Re: Tromox Mino
Everything setting i change, keeps changing back every time i push upload, is there anything else i need to do, to be able to change settings?
Schnabelwesen
PLZ: 2411
Re: Tromox Mino
Beitrag von Schnabelwesen »
Hi Danish tromox,
the Lingo controller works the other way round. Upload means uploading from the controller to the computer. Download is correct: with this you download your settings to the controller.
Best regards, Bertolt
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
I couldn't change the speed limit by any settings in the OEM Controller. Maybe you'll have better luck.
Zurück zu „Tromox“
