[EVO,100,R] CAN/ECU Bus Reverse Engineering (Roller + Batterie)
- Roller: MQi GT EVO
- PLZ: 67
Re: [EVO,100,R] CAN/ECU Bus Reverse Engineering (Roller + Batterie)
Hi,
thats no problem.
If you have basic electronic skills:
Just buy a LilyGo T-CAN485 and a Honda 6 Pin diag plug from AliExpress or eBay and flash my firmware onto it: https://git.0-c.de/Crash_Override/NIU_C ... eryChecker
I am working on a One-Click flashing solution but it is not ready yet. So follow instructions on git.
Then you can charge your batteries with the 3rd party charger. I recommend to open your charger up and limit the voltage to 82,6V, to have some headroom to max voltage of the cells. There are often small potentiometers on the control PCB.
Otherwise I have one T-CAN and a Diag lead left, I can ship you.
Do not exceed 10 Amps of charging current if you use the original socket. You can go up to 20Amps charge current (I tested so far) but with a dedicated charging lead connected to the FOC. https://elektroroller-forum.de/viewtopi ... 39#p364739
thats no problem.
- Roller: Evo
Yes, can I buy it from you? A pre flashed T-CAN? I bought a Lilly on AliExpress, but I would prefer it preflashed by you. I'd like to enable battery charging on start up, I think that's one of your latest versions. Thank you!zock3r1608 hat geschrieben: ↑Mi 25. Jun 2025, 21:59
I have another question. The Honda 6pin connector is necessary for charging the batteries or just for the testing tool?
Zuletzt geändert von LOrange am Do 26. Jun 2025, 08:38, insgesamt 1-mal geändert.
- PLZ: 67
You need to get the CAN messages into your EVO. The way without soldering a extra socket is to use the already present diag socket.
At the moment there are not charge plugs 2+7 available to buy separate.
I have one left here, I can ship to you.
- Roller: Evo
Okay I thought I needed to solder the Can High and Can Low to the charging cable, so it could transmit to the charging port. Would you show me a picture of the Honda 6Pin connection for charging? Thanks!zock3r1608 hat geschrieben: ↑Do 26. Jun 2025, 11:49You need to get the CAN messages into your EVO. The way without soldering a extra socket is to use the already present diag socket.
And please tell me a way I can pay you for the Lilly Can charger emulator. You can send me a private message
- Roller: Evo
I've already cut my NIU original cable to provide 84v to the original socket. Can I use this diagram to connect everything directly to the Scooter's charging socket? Or I should use the LillyGo connected to the diagnosis Honda 6 pin socket and the 84v to the charging socket? Thanks!solid hat geschrieben: ↑Mi 25. Jun 2025, 21:54Hi! Yes, get a Lilygo T-CAN485 and flash Crash_Override's firmware. You'll need an original EVO charger connector and a 12V source, either from the EVO 12V battery or from an external 12V power supply and connect it safely.
For further reading: https://git.0-c.de/Crash_Override/NIU_C ... eryChecker
Translated to German:
Ich habe mein originales NIU-Kabel bereits abgeschnitten, um 84 V an die Originalbuchse zu liefern. Kann ich dieses Schaltbild verwenden, um alles direkt an die Ladebuchse des Rollers anzuschließen? Oder sollte ich den LilyGo mit der Diagnose-Honda-6-Pin-Buchse verbinden und die 84 V an die Ladebuchse anschließen? Danke!
- solid
- Roller: NIU MQi GT Evo
- PLZ: 8
Either will work. I use my setup to charge the batteries outside of the scooter, so everything goes into the original plug.
AFAIK, zock3r1608 uses a XT60 connector for 82,6V charger and Honda 6 pin connector for Lilygo T-CAN485, it works just as well.
- Roller: Evo
Thanks for your answer. I will then try to install everything to charge with the original socket. Just to know, on the diagram you sent there are different colours for the cables. Do they match with the original cables inside the original charger lead? Thanks!
In German:
Danke für deine Antwort. Ich werde dann versuchen, alles so zu installieren, dass ich über die Originalbuchse laden kann. Nur zur Info: In dem Diagramm, das du geschickt hast, sind verschiedene Farben für die Kabel angegeben. Entsprechen diese den originalen Kabeln im Ladekabel des Original-Ladegeräts? Danke!
- solid
- PLZ: 8
You're welcome. Yes, they match with the original EVO plug cable colours. Please note this isn’t intended as a set of instructions, and I can’t be held liable for any damage. Basic electrical‐engineering knowledge is assumed and it’s still wise to verify all pins and cables with a multimeter.
- Roller: Evo
Hello guys! I received my LillyGo TCAN from Aliexpress, I flashed it with zock3r1608's firmware and now I can charge my scooter! Thank you so much for the code and the explanations. I noticed that when the LillyGo TCAN is connected to the scooter's charging socket, it doesn't need the external 12V input, so I decided not to install it, since I will charge only while connected to the NIU EVO.
Again, you saved my scooter with all this information and I'm so grateful.
I wanted to donate to @zock3r1608 but I couldn't find the PayPal or Kofi, please send it to me so I can donate.
Greetings from Spain!
In German:
Hallo Leute!
Ich habe mein LillyGo T-CAN von Aliexpress erhalten, die Firmware von zock3r1608 geflasht und jetzt kann ich meinen Scooter laden! Vielen Dank für den Code und die Erklärungen.
Ich habe festgestellt, dass der LillyGo T-CAN, wenn er an die Ladebuchse des Scooters angeschlossen ist, keine externe 12V-Stromversorgung benötigt. Deshalb habe ich mich entschieden, diese nicht zu installieren, da ich nur laden werde, wenn der T-CAN mit dem NIU EVO verbunden ist.
Nochmals: Ihr habt meinen Scooter mit all diesen Informationen gerettet und ich bin euch sehr dankbar.
Ich wollte @zock3r1608 etwas spenden, aber ich konnte kein PayPal- oder Ko-fi-Konto finden – bitte schick mir die Infos, damit ich spenden kann.
Grüße aus Spanien!
In German:
Hallo Leute!
Grüße aus Spanien!
- PLZ: 67
Hey,
nice its working for you. Did you solder on the original Charging Lead or how do you exactly realize this. A picture would be nice too
Sorry had not much time last days.
Mitglieder in diesem Forum: Ascheloche, Bergziege, Bing [Bot], Google [Bot] und 16 Gäste
